GPU renderers and flip fluids
GPU renderers are not a good fit for most visual effects shots because of the memory limitations of the GPU compared to the main system memory (e.g. 12GB and 128GB). If the renderer can use the main system memory or use the CPU as a backup it's more fitting for visual effects when the project inevitably hits a memory ceiling while rendering on the GPU. I've tried Octane in Houdini and was not impressed at all. Yeah, a lot of stuff was fast but a lot of stuff was also broken. I haven't tried Redshift in anything yet.
Luke, thanks. A quick search seems to confirm your assessment. Very, very few demos I can find of gpu rendered fluid sims. If anyone can prove me wrong, please do!
so, out of curiosity are you a Mantra only advocate in Houdini?
And what type of hardware are you running?
As a novice, my logic for GPU renders goes something like "quicker renders = more iterations = faster learning" but if my focus is fluid, particle sims might be time to recalibrate my thinking.
I advocate for using the right tool for the job. In many cases for visual effects this is Mantra.
Dual socket machines with 20 cores (40 threads) and 128GB of memory. The more cores the better.
In production more iterations usually means a better final product. This will help your schoolwork turn out better given the same amount of time but I wouldn't go so far as to say you'd learn more. That's an entirely different story.
  • 2 weeks later...
