6ril Posted September 19, 2016 Share Posted September 19, 2016 Hello, I'm trying to control some particles, I need them to travel on a ground, toward an object, then creep up on that object surface, when they reach it. I've tried a few method (creep, ray, slide on collision ...) but even if I manage to have them slide on an object surface, my problem is how to set up the POP network in order to have them transitioning from one surface to another. I've cheated with a P.y = 0 in order to have them on the ground with ease, but I'm failing at controlling a nice transition from ground to object. here is a basic setup, without much, in order to not restrict the different approaches . Also, I'll replace the particle with a small disk later, so I think I need them (particles) to be oriented properly. Thanks for any advise and help! prtcl_slide_4OD.hipnc Quote Link to comment Share on other sites More sharing options...
Atom Posted September 19, 2016 Share Posted September 19, 2016 Check out Sohey's approach to solving insects crawling on the ground then up the sides of obstacles. Quote Link to comment Share on other sites More sharing options...
angelous4x Posted September 19, 2016 Share Posted September 19, 2016 Hey 6ril I check your file, just VDB all the geo, and used a raycast in a sop solver and used a pop attract to force it up the geo. it not totally accurate, but it crawled along and up the geo. let us know how it works out. cheers prtcl_slide_VDB_and_raycast.hipnc Quote Link to comment Share on other sites More sharing options...
6ril Posted September 19, 2016 Author Share Posted September 19, 2016 @atom Thanks ! your knowledge of this forum often amaze me ! And that discussion you pointed me to seems very interesting ! I'll check if this approach can deal with deforming object. @angelous4x thanks! simple and effective. I'll look into it as well. Quote Link to comment Share on other sites More sharing options...
