art3mis Posted January 9, 2017 Share Posted January 9, 2017 Not sure if it effects other distros, but there is an annoying default behavior when you ALT-Left Mouse button click in Ubuntu. It moves the entire application Window. This is a common question but no universal solution it seems I've tried the most common solution, modifying the Mouse setting in dconf Editor, org>GNOME>desktop>wm>preferences but afaik IT DOES NOT WORK in Ubuntu mate 16.04. Anyone else have a solution that would work or I can at least try? Quote Link to comment Share on other sites More sharing options...
lukeiamyourfather Posted January 9, 2017 Share Posted January 9, 2017 You might have to start a new session for the change to work. If that doesn't work you can switch to another desktop environment until they fix the bug (assuming it's a bug). You're changing mouse-button-modifier property, right? Quote Link to comment Share on other sites More sharing options...
art3mis Posted January 9, 2017 Author Share Posted January 9, 2017 ok thanks. Think i figured it out. Pretty sure I was changing in the wrong place Need to go org → mate → Marco → general → mouse-button-modifier Quote Link to comment Share on other sites More sharing options...
