Blacko0ps Posted January 14, 2017 Share Posted January 14, 2017 Hi Guys I am trying to make bunch of crawling earthworms using FEM in Houdini. This is my references : https://vimeo.com/53813166 I really need have control on path of each worm. My question is that how should I add path deformation to the simulation. I have tried to add it before tetrahedralizate node, but it affects on the geometry points. Thanks Quote Link to comment Share on other sites More sharing options...
Atom Posted January 14, 2017 Share Posted January 14, 2017 Have you seen Sam's work on earthworm locomotion? Quote Link to comment Share on other sites More sharing options...
Blacko0ps Posted January 14, 2017 Author Share Posted January 14, 2017 (edited) Thanks for reply! Yes, but in his setup the worm moves on a straight path. I wanna have a curvish path for each worm that I can have control over it. Like the reference that I have posted Edited January 14, 2017 by Blacko0ps Quote Link to comment Share on other sites More sharing options...
Atom Posted January 14, 2017 Share Posted January 14, 2017 Here is a simple example of deforming along a curve. I did not make the deforming scene, I found it floating around the forum. I exported the earthworm from Sam's scene and brought it into this deform along path example. You'll need to come up with a way to create more curves and copies. ap_path_deformer_worm.hipnc 1 Quote Link to comment Share on other sites More sharing options...
Blacko0ps Posted January 14, 2017 Author Share Posted January 14, 2017 Thanks man, but if I add organic tissue to example it will lose its animation. Sorry if I didn't explain it clearly. My question is that how can I convert your example to FEM and still have it moving along the path. Quote Link to comment Share on other sites More sharing options...
Atom Posted January 14, 2017 Share Posted January 14, 2017 (edited) I don't think FEM supports deforming input geometry at this time of Houdini 15.5. I assumed you might simply simulate a single worm moving in a straight line then deform that pseudo organic animated sequence after the simulation is complete. Here is another attempt at deforming the worm after the fact. Using a FOREACH loop for each curve produced by Matt's wire solver you can get a number of worms moving along randomly over top one another. Increase the curve count to add more worms. ap_me_wire_worms_along_path.hipnc Edited January 14, 2017 by Atom 5 Quote Link to comment Share on other sites More sharing options...
Blacko0ps Posted January 14, 2017 Author Share Posted January 14, 2017 Thank you so much man! I think this somehow could work. Quote Link to comment Share on other sites More sharing options...
mattvfx Posted January 14, 2017 Share Posted January 14, 2017 you can use a target mesh to influence your FEM simulation or a animated rest mesh . http://ihoudini.blogspot.com/2013/12/worm-locomotion-with-fem.html 1 Quote Link to comment Share on other sites More sharing options...
Blacko0ps Posted January 14, 2017 Author Share Posted January 14, 2017 Hi Matt, not sure about target mesh, is it same as Point deform node? I have tried adding rest position to my animated mesh, but when I transfer it to FEM simulation it lose the animation. Quote Link to comment Share on other sites More sharing options...
mattvfx Posted January 15, 2017 Share Posted January 15, 2017 (edited) you can import the target mesh or the rest mesh in the solid object dop node . then you have to use the targetStiffness targetDamping or pintoanimation per point attributes . in the finite elements master class from sesi you can learn how to set-up the target mesh. Edited January 15, 2017 by mattvfx 1 Quote Link to comment Share on other sites More sharing options...
Blacko0ps Posted January 18, 2017 Author Share Posted January 18, 2017 (edited) Thanks Matt! it seems works for different kind of deformation, but not path deformation. I think I'll use the wire solver method that Atom mentioned above, at least gives me closer result. Edited January 18, 2017 by Blacko0ps Quote Link to comment Share on other sites More sharing options...
anthonymcgrath Posted January 18, 2017 Share Posted January 18, 2017 the worms setup with the wire solver is luuuuurrrrvely! It might be worth using that to get your initial deformation - then pass that little lot through a fem solver to get some gravity and nice intercollision between them! target geometry is fairly easy to do overall - i used it to get these squidgy things to move under animator control by simply animating a translating/rotating version of the geometry and using that as target. The same for the rest geo - but you need to ensure both of these things are using the same tetrahedralised result otherwise it just tends to bork out and go weird. also when using rest/target you need to turn up the value in the solver too otherwise it wont do a great deal - theres a stiffness and damping for your target. 3 Quote Link to comment Share on other sites More sharing options...
Blacko0ps Posted January 22, 2017 Author Share Posted January 22, 2017 (edited) Hi Anthony, Very nice work on your FEM animation! I have been trying add FEM to the wire solver result, but again whenever I add the FEM it loses its animation. Still figuring out how to work with target geometry, but I couldn't get it to work. Also, my second question is that, I have bunch of seeds that I want them to have interaction with my worms. Something like worms are crashing and eating the seeds. Do you think would be the best approach for that? I have attached my file here Worm_10.hipnc Edited January 22, 2017 by Blacko0ps Quote Link to comment Share on other sites More sharing options...
