Bakiki Posted February 1, 2017 Share Posted February 1, 2017 Could someone explain how to render a pyro smoke effect with redshift. I can render a basic volume by not a pyro. I would appreciate it some could provide a simple hip file with a basic sphere converted to any pyro with the applicable shader. I'm trying to get my head around how to connect a volume shader with a pyro.. Many many thanks Quote Link to comment Share on other sites More sharing options...
chrisdunham95 Posted February 1, 2017 Share Posted February 1, 2017 May not have the answer to your question but will provide general help with redshift i imagine by the master rohan - Quote Link to comment Share on other sites More sharing options...
mine Posted February 1, 2017 Share Posted February 1, 2017 A basic pyro shader: 1 Quote Link to comment Share on other sites More sharing options...
Bakiki Posted February 1, 2017 Author Share Posted February 1, 2017 Thanks for the suggestions. I have seen both these and yet I can't get an rendered image. Is it a case of just adding a RSvolume with those settings the pyro_import of the sim? Doesn't work for me...? Thank again Quote Link to comment Share on other sites More sharing options...
mine Posted February 1, 2017 Share Posted February 1, 2017 it worked for me when I tested it. Maybe you can share your hip file? Quote Link to comment Share on other sites More sharing options...
Bakiki Posted February 1, 2017 Author Share Posted February 1, 2017 It's probably a really obvious mistake I'm making. Here's the hip file.... pyro attempt.hipnc Quote Link to comment Share on other sites More sharing options...
mine Posted February 1, 2017 Share Posted February 1, 2017 (edited) I can't see the problem, it all seems right, but it doesn't seem to be a problem in the redshift shader because your volume doesn't even render in mantra, right? Edited February 1, 2017 by mine Quote Link to comment Share on other sites More sharing options...
Bakiki Posted February 1, 2017 Author Share Posted February 1, 2017 It renders in mantra when I put a pyro shader and mantra rop....? Quote Link to comment Share on other sites More sharing options...
Sepu Posted February 2, 2017 Share Posted February 2, 2017 well you uploaded a .hipnc which redshift doesn't support. you have to have indie or fx to render with 3rd party renders. Quote Link to comment Share on other sites More sharing options...
