Image sequence texture error
Hi everybody
I want an animated texture map in my shader and I assume a $F is the way to go but unfortunately the texture vop just raise this error: "Cannot have channels which depend on time."
Although the path evaluate correctly in texture node the render sticks to frame 1 texture. So what am I doing wrong?
Thank you.
  • 4 years later...
