Update RBD goal in DOPs
Pancho
In order to make my RBDs follow a deforming mesh I need to update the constantly changing goal position. I guess I need to do this in the DOP itself, since the packed geometry doesn't seem to transfer this update into the DOP by itself.
Each packed RBD object has its own goal which I assign inside a attrVop by comparing IDs of two scattered point clouds with the same number of points. I guess I need to do something similar inside the DOP. Is this they way to go?
Cheers
Tom
Not sure I understand your issue, but, can't you use pops? Packed geo behave much like points and with pop dops you can control movement much finer
Although I'm curious why would you do a rbd simulation of something you want to follow some arbitrary path, isn't that a little counter intuitive?
In this case I want to make the RBD follow the point positions on a mesh. But not in the way that they stick to the mesh, but are attracted to the points by force.
A practical example could be to advect the RBD to particles inside of a flip simulation in order to achieve a sim which behaves like a fluid sim, but consists out of RBD objects.
Thanks for the tip with the popAttractNode.
But my problem remains. How do I alter an attribute inside of a dop network which depends on something outside of the dop network. I need to import the geometry, but already fail here. In my inital SOP for the RBDs I assign my goal inside of an attrbuteVop. Import Point Attribute with OpInput2 for file and ptnum as ptnum. Bind to assign it.
Although there is a popVop inside of the dopNetwork it lacks the possibility to plug in a second input. If I try to use the ImportPointAttribute and set file to something like /obj/rbd/OUT_goals then the imported P attribute turns out to be 0,0,0. So I guess this doesn't work.
So, how do I import the data correctly and assign it to the particles/packed objects?
Cheers
Tom
if you have something connected to the second input of your Dop make sure that on the Pop Vop > Inputs Tab > Second Context Geometry is selected.
If you want to change a value add subtract, etc you need to use a Sop Solver just in case.
Edited by Sepu
I typically use PopSteerSeek and just use VEX to overwrite the goal variable with location of my goal for each particular point. This require a goal vector to be assigned to each point but it does simplify seeking. Then you can use  the braking controls to adjust how each point arrives.
goal = set(v@goal_location[0],v@goal_location[1],v@goal_location[2]);
Thanks so much, guys! When I dissected the PopSteerSeek I came across the POP VOP in the network and realized that the other inputs are "hidden" and not on top of the node. So, specifiying a SOP path pointing to my object was good enough to use the import point attribute inside of of the POP VOP.
Man, I didn't see the woods because of all the trees. : )
