siris Posted April 3, 2017 Share Posted April 3, 2017 (edited) Hello all, I've hit a new problem, which is my object will not fill all the way, it stops when the emitter is under water. I've read on here that I could use the expand tool in the populate containers shelf, but when I do this it won't let me select my fluid. I tried another way of adding divergence, but I'm over my head as a new user. Here is a link to my scene file and the abc that goes wth it (attach it to the figure_geo). Dropbox - scene files If someone could please help me figure this out I'll be very grateful, I have a deadline for uni looming over me and I'm incredibly stressed out! Edited April 3, 2017 by siris Quote Link to comment Share on other sites More sharing options...
Atom Posted April 3, 2017 Share Posted April 3, 2017 Here is your scene setup with a Divergence Field. The pressure is set to 1.0 in this scene. If you need less, lower it. You can also animate it so the pressure is only present in the last half of the animation. To get the fluid to fill the hand/finger area you will probably need a lower particle separation. Try 0.03 perhaps..? ap_FillObject.hipnc 3 Quote Link to comment Share on other sites More sharing options...
Noobini Posted April 4, 2017 Share Posted April 4, 2017 (edited) so with the orig file...I thought the human body wasn't reacting right with the particles because the normals weren't right, it was pointing outwards rather than inwards...but that is not the real cause ? EDIT: ahhh don't worry...found the Invert Sign thing... Edited April 4, 2017 by Noobini Quote Link to comment Share on other sites More sharing options...
Atom Posted April 4, 2017 Share Posted April 4, 2017 (edited) Yep, you go it. When your emitter is inside a collision object you have to Invert The Sign of the collision object. Edited April 4, 2017 by Atom Quote Link to comment Share on other sites More sharing options...
siris Posted April 10, 2017 Author Share Posted April 10, 2017 @Atom - Thank you so much for helping me. My apologies for the late reply, I didn't realise anyone had responded. Quote Link to comment Share on other sites More sharing options...
