Stranger things - Elastic wall effect?
dyei nightmare
which tool should i use for this effect like those in  stranger things sitcom effect?  FEM?  cloth?  wires?  pop-grains?? lattice?   basically i want good colision  resolution and not very long simulation times with a lot of elaticity.   are there any aproach out there?
I don't think shrinkwrap really is the effect in question. It is simply pushing a mesh against a rubber sheet, right? With the help of AdrianR on Discord I put together this simple example. To get more detail out of the effect you will have to increase the grid resolution and then recapture the points along the edge using the Follow Target tool (i.e. cloth pinning) on the Cloth shelf.
ap_pig_stretches_rubber.hiplc
  • Like 4
