Anti-Distinctlyminty Posted May 14, 2017 Share Posted May 14, 2017 Hi all, I wasn't sure whether to put this into shading or effects, so it just ended up here. The title says it all - is there a way to move points at render time? Just apply a noise or something like that, essentially a render time VOP Network. The reason is I have a heavy piece of geo that just needs to sit in the background and wobble slightly. That's all. It seems very wrong to write out geo for every frame. Quote Link to comment Share on other sites More sharing options...
catchyid Posted May 14, 2017 Share Posted May 14, 2017 cannot you use displacement (i.e. translation along normal maps) for that? If this is what you need, then it's possible (I don't know details though!). But I am thinking, if you just want it to move slightly side to side only (i.e simple translation), why don't you just animated it's translation? Maybe you can do both, use translation to do side to side and normal maps to add more character to it... Quote Link to comment Share on other sites More sharing options...
Anti-Distinctlyminty Posted May 14, 2017 Author Share Posted May 14, 2017 Unfortunately no, neither of those will work. What I'm after is some sort of underwater wavy motion. I can do this just fine, but it means I have to write geo out for every frame, which is very wasteful. Imagine you are rendering something like some underwater kelp gently swaying in the current. A simple moving displacement will work fine, but I cannot see how that can be done. Quote Link to comment Share on other sites More sharing options...
Atom Posted May 15, 2017 Share Posted May 15, 2017 To me there is nothing wrong in writing out geo. My final scenes are often just a bunch of playback nodes of geo sequences. What are you saving that disk space for anyway, Christmas (my Duke Nukem reference...) Quote Link to comment Share on other sites More sharing options...
Anti-Distinctlyminty Posted May 15, 2017 Author Share Posted May 15, 2017 4 hours ago, Atom said: To me there is nothing wrong in writing out geo. My final scenes are often just a bunch of playback nodes of geo sequences. What are you saving that disk space for anyway, Christmas (my Duke Nukem reference...) We can have very long shots (my current one is 3200 frames) with heavy geometry. You can see my issue I'm sure Quote Link to comment Share on other sites More sharing options...
Atom Posted May 15, 2017 Share Posted May 15, 2017 I work with long frame counts too. But I can see your point if you are short on disk space. Displacement does seem like a solution whether you do it pre or post render. Quote Link to comment Share on other sites More sharing options...
