pushing FEM object using pyro
dansidi
Hi everyone,
I am trying to bend some trees using a rocket exhaust.
I have created a pyro sim for the rocket exhaust, which I have cached cached. I have also created trees in L-systems and made them in to FEM objects.
I have been able to use a magnet force in the FEM simulation to deform the trees, but I want to use the pyro sim to force the trees to bend.
I assume this is possible, but I do not know how to connect the cached pyro sim to the FEM simulation.
I have been trying to use the FieldForce DOP with a SOPvetorField plugged into the data, but I have no idea how to configure these nodes.
Can anyone help me with getting this to work?
Thanks!
Dan
l-system_test_04.hip
Thanks for your help, Atom.
I suppose sometimes the simplest solution will be good enough!
Is it possible to connect those simulations, though?
Edited by dansidi
regret!
yes, Yes, YES !!!!
Thanks Paul.
I had to modify a bit, but your setup has shown the way. Thanks a lot!!!!
Inside the SOPsolver, I reversed the velocity vector.
Here is a test render and scene file.
l-system_test_05.hip
l-system_test_05_H264.mov
Edited by dansidi
forgot a detail
  • Like 2
