SOP Solver - Overwriting Parameters
Fiszka
Hey. I have a problem with overwriting values from wire object in SOP Solver. If klinear parameter (Linear Spring Constant) is set to 300 in wire object and then I'm writing inside sopsolver in point wrangle @klinear = 300; just for test, then my simulation looks different, less stabile (?). Why is that happening? This is the same value so it should be the same sim. I was trying to put sopsolver before and after the wire solver and there was the same situation.
