VEXpression Presets
Noobini
YEEEEEEEEEEEEEEEEEEEEEEEEESSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSS
At long last...I've worked out the preset for this
Select Ends: (First/Last of a prim, will work on non curve too...but would probably be next to useless, try the pig :huh:)
groupexpression/snippet
    Ends (or First/Last)
    vertexprimindex(0, @vtxnum)%(primvertexcount(0,@primnum)-1)==0
As you can see, No, you don't need to use a for each prim loop...just a groupexpression.
Edited by Noobini
1 hour ago, anim said:
did you ever need a loop?
the way i used to do it was groupbyrange, Start 1 End 1, Invert Range, then for multi lines yes i would need to put it thru a for each prim loop or for each connected piece
just FYI, recc by a hou.alex.get on SESI forum
https://www.sidefx.com/forum/topic/72597/?page=1#post-307209
Now, I'm putting file in: (so hopefully next uninstall/install i won't lose my custom presets)
C:\Users\xxx\Documents\houdini18.0\
(note:the entries double up so you'll have to clear out what's already the default contents and include only YOUR custom presets in there)
Yes, definitely put your custom VEXpressions.txt in the user directory, much safer than editing the original file.  The user directory VEXpressionl.txt file will get automatically appended to the SESI version, so only add the custom expressions starting from a blank file (not a copy of the SESI version).
