Strange Bullet Solver Motion
Hi
Encountering some strange Bullet Solver motion in a simulation.
Using the RBD Fractured Object shelf tool and a GroundPlane for collision. So the only force should be gravity. But after the fractured pieces hit the ground many of them continue to swim around as if affected by some sort of turbulence. And if I look under the ground plane I can see they actually pass right through creating a sort of debris cloud. Very strange
Can anyone suggest what might be happening?
Edited by art3mis
Thanks guys. Setting defaults helped a bit but the main problem was I needed to enable "Create Convex Hull..." on RBDPackedObject node. However there is still some type of collision issue. Almost as if the ground plane was water and the smaller fractured pieces are bobbin in the water.
Edited by art3mis
so is substeps a bit higher than 1 now ? also do you HAVE to use parallel constraint solver ? my (pure) guess is you're using parallel constraint solver....with artificially high gravity + substeps 1....leads to artifacts/swimming
