Pyro | Multiple Sources with Unique Microsolvers?
ParticleSkull
Hey Alvaro,
Here is a bit over-complicated setup using a vector field to define the id masks, but you can use also scalar fields directly. In this setup I'm using the id masks ( aka source A, sourceB ) to affect dissipation and turbulence for each source, please look into those "shapers" in the pyro solver.
I hope this helps you!
Cheers!
Alejandro
multi.pyro.v1a.hiplc
Edited by Pazuzu
  • Like 3
Guys, you're freaking awesome :D
Alejandro, it's perfect but it looks a bit complicated for me atm. It's an excellent scene to study and I'll definetelly dissect and recreate it later
Paul, thank you very much, that's it and it looks so simple! I'll make some tests right now
