Houdini Ocean Toolkit
Jason
Hi Drew.
I have the same gcc version:
Gondor:temporal user$ gcc -v
Using built-in specs.
Target: i686-apple-darwin9
Configured with: /var/tmp/gcc/gcc-5465~16/src/configure --disable-checking -enable-werror --prefix=/usr --mandir=/share/man --enable-languages=c,objc,c++,obj-c++ --program-transform-name=/^[cg][^.-]*$/s/$/-4.0/ --with-gxx-include-dir=/include/c++/4.0.0 --with-slibdir=/usr/lib --build=i686-apple-darwin9 --with-arch=apple --with-tune=generic --host=i686-apple-darwin9 --target=i686-apple-darwin9
Thread model: posix
gcc version 4.0.1 (Apple Inc. build 5465)
Here´s the compiling output from my system:
Gondor:temporal user$ hcustom -e SOP_Star.C
g++ -DUT_DSO_TAGINFO='"3262197cbf075a1131862a87493e9eee6542daf3ce2e99fa6da8f77b5847f185379b21c0d07c73344332f8ed67bb645b4beee110fed6e351400c2ded77f891bc429445a0ff924994a3268d4a1ea011fcfe1d90a2e5"' -DVERSION=\"10.0.295\" -DDLLEXPORT=  -D_GNU_SOURCE -DMBSD -DMBSD_COCOA -DMBSD_INTEL -arch x86_64 -DAMD64 -fPIC -DSIZEOF_VOID_P=8 -DSESI_LITTLE_ENDIAN -DENABLE_THREADS -DUSE_PTHREADS -D_REENTRANT -D_FILE_OFFSET_BITS=64 -fobjc-gc-only -c  -DGCC4 -DGCC3 -Wno-deprecated -I/Library/Frameworks/Houdini.framework/Versions/10.0.295/Resources/toolkit/include -I/Library/Frameworks/Houdini.framework/Versions/10.0.295/Resources/toolkit/include/htools -Wall -W -Wno-parentheses -Wno-sign-compare -Wno-reorder -Wno-uninitialized -Wunused -Wno-unused-parameter -O2 -DMAKING_DSO -o SOP_Star.o SOP_Star.C
cc1plus: warning: command line option "-fobjc-gc-only" is valid for ObjC/ObjC++ but not for C++
g++ -bundle SOP_Star.o -arch x86_64 -fobjc-gc-only -framework OpenGL -framework Cocoa -rpath,@loader_path/Libraries -Wl,-rpath,/Library/Frameworks/Houdini.framework/Versions/10.0.295/Libraries -L/Library/Frameworks/Houdini.framework/Versions/10.0.295/Libraries -L/Library/Frameworks/Houdini.framework/Versions/10.0.295/Resources/Frameworks/Houdini.framework/Versions/10.0.295/Libraries -F/Library/Frameworks/Houdini.framework/Versions/10.0.295/Resources/Frameworks -framework Houdini -o /Users/user/Library/Preferences/houdini/10.0/dso/SOP_Star.dylib
ld: in /Library/Frameworks//Python.framework/Python, missing required architecture x86_64 in file
collect2: ld returned 1 exit status
The main problem I am having is:
Should I have a Python build for 64bits installed in my system in orden to compile this code ? I don´t compile files on a regular basis, so please excuse me if I am doing something wrong.
Gondor:temporal user$ file /Library/Frameworks/Python.framework/Python
/Library/Frameworks/Python.framework/Python: Mach-O universal binary with 2 architectures
/Library/Frameworks/Python.framework/Python (for architecture ppc):	Mach-O dynamically linked shared library ppc
/Library/Frameworks/Python.framework/Python (for architecture i386):	Mach-O dynamically linked shared library i386
"I'm not a Mac expert either but mabye it's to do with using an older OSX version ?" -> I have the latest, updated OS X version, 10.5.7
Thanks.
SYSTEM CONFIGURATION:
Mac Pro 2 x 2.66 GHz Dual-Core Intel Xeon
Mac OS X Version 10.5.7
6 GB RAM
Developer tools installed from OS X Leopard DVD, Xcode version 3.0, gcc v.4
MacPython 3.0
Houdini apprentice HD (with paid license), v10.0.295
Edited by Hyperion
  • Replies 42
  • Created
  • Last Reply
Top Posters In This Topic
I'm not sure why python is coming in to the equation here since it isn't explicitly linked and shouldn't be needed. So, if you have installed a separate non Apple python it may be the problem. I'd try removing it and see what happens.
-Drew
You were totally righ !!! I previously intalled another version of Python, and that was the bug. Now HOT has been compiled w/o any problem.
After removing the Python 3.1 framework form the machine, everything was fine !
Just in case any other user has the same problem, have a look at this, in order to uninstall MacPython:
http://docs.python.org/using/mac.html
Many thanks !
