gerescm Posted September 11, 2017 Share Posted September 11, 2017 Hi all, I want to import a particle simulation from houdini to Maya without using the Houdini engine and render in Redshift. I made a way around it stamping spheres into particles and exporting them as Alembic, but the file is too damn heavy. Do you have any suggestion? Thanks in advance. Quote Link to comment Share on other sites More sharing options...
Atom Posted September 11, 2017 Share Posted September 11, 2017 If your Houdini app is on the same machine as the Maya app, why not just render directly out of Houdini? The Redshift license works for all apps on the same machine. Quote Link to comment Share on other sites More sharing options...
gerescm Posted September 11, 2017 Author Share Posted September 11, 2017 34 minutes ago, Atom said: If your Houdini app is on the same machine as the Maya app, why not just render directly out of Houdini? The Redshift license works for all apps on the same machine. Thank you for your reply, that is actually a good way to do it but it would involve recreate the whole scene in houdini, doesnt it? Quote Link to comment Share on other sites More sharing options...
Sepu Posted September 11, 2017 Share Posted September 11, 2017 You should be able to transfer the particles as a redshift proxy. Quote Link to comment Share on other sites More sharing options...
gerescm Posted September 12, 2017 Author Share Posted September 12, 2017 16 hours ago, Sepu said: You should be able to transfer the particles as a redshift proxy. Thank you for your answer, how can I export the proxy from Houdini? Quote Link to comment Share on other sites More sharing options...
Sepu Posted September 12, 2017 Share Posted September 12, 2017 (edited) The Rop has a tab call archive, check that and make sure that you render the whole sequence, if you want to make sure that you are just saving the particles go the object tab use the force objects. or just select the particles and and check "Export only selected objects" Edited September 12, 2017 by Sepu 2 Quote Link to comment Share on other sites More sharing options...
gerescm Posted September 12, 2017 Author Share Posted September 12, 2017 4 hours ago, Sepu said: The Rop has a tab call archive, check that and make sure that you render the whole sequence, if you want to make sure that you are just saving the particles go the object tab use the force objects. Thank you so much! Quote Link to comment Share on other sites More sharing options...
Tex Posted October 11, 2017 Share Posted October 11, 2017 Fwoaar I've been bashing my head around with Engine trying to figure this out, I would never have thought of RS proxies. Thanks! Quote Link to comment Share on other sites More sharing options...
Sophie Posted August 15, 2018 Share Posted August 15, 2018 Could anyone tell me what rop node this is? Do you need like a plugin for redshift? Haven't used it before and would love to try! Quote Link to comment Share on other sites More sharing options...
gerescm Posted August 15, 2018 Author Share Posted August 15, 2018 Yes you need to install Redshift in order to export rs proxies to Maya.\ If you want to export your particles to Maya you can use the Houdini Engine to bring them in. Quote Link to comment Share on other sites More sharing options...
