HQueue Problem
nikola014
Yeah log into the clients with the account they will be using and make sure they have access/permission to read/write to the necessary drives. It seems silly but this where most issues stem from. HQueue is pretty simple in the grand scheme of render engines.
You will always need a license per each client/process. Mantra Render tokens are free so you just need to ask your SideFX representative and they will grant you them. As for processing geometry on the farm you will need Houdini "Engine" licenses these used to be called hbatch licenses. They cost a bit, but you can also use Houdini in any other host application you want nowadays, too, so they make it worth while.
Great,thank you very much,that's it.
