Connecting nodes to different inputs by Python Lang
Bart87
I am trying to do my asset for houdini and I am looking a method which can allow me to connect one node to anoter
I use something like this, but this option is connecting everything to imput1 ('grey imput')
    staticsolver = doptoolutils.createSolver("staticsolver", True) - create staticsolver node
    staticobject = dopnet.createNode("staticobject") - create staticobject node
    doptoolutils.addObjectToSolver(staticobject, staticsolver, True) - connect staticobject to staticsolver
but some nodes has more inputs:
multisolver has 2 inputs one is grey and another purple - how I can connect my node to the purple one using python language?
and another constraintnetwork has 3 inputs, one grey, green and purple
and also if merge node has 3 inputs connected, how I can tell which should be first?
I need explanation how I can connect something to each input. I found something like this but I dont understand what I should write to make it works:
http://www.sidefx.com/docs/houdini/hom/hou/NodeConnection.html#outputNode
if someone can write to me an example how should I write my script lines which show how I should connect node to purple input in multisolver, how to connect to green and purple input for constraintnetwork and how to define which is the first input in merge node.
I attached picture as example what I want to connect to.
Thank you
Bart
Check out the help docs on setInput() function. You need two variables, the node to connect and the node to connect to.
The value of 0 is the zero based input to connect to.
node_source.setInput(0,node_target)
node_source.setDisplayFlag(True)
node_target.moveToGoodPosition()
Edited by Atom
I have done something like this, but doesnt work
staticsolver = dopnet.createNode("staticsolver")
staticobject.setInput(0,staticsolver)
staticobject.setDisplayFlag(True)
staticsolver.moveToGoodPosition()
Edited by Bart87
screenshot
1 hour ago, Atom said:
Wouldn't it be the other way around?
Did you try...
staticsolver.setInput(0,staticobject)
Hay, I found the mistake
there should be
staticsolver.setInput(0,staticobject,0)
1st zero is for input to my staticsolver and 2nd zero is for my staticobject output.
so you only missed one zero but its help me a lot to understand what to do...
Thank you!!!
Edited by Bart87
