Fluid is not flowing
PhiiLL
from my hillbilly experience........if you want more flowing milk........you gotta squeeze more.....
(in flipfluidobject, just make particle sep. 0.05 instead of 0.1)
Edited by Noobini
Expand
that helped, thank you <3
But now my fluid is splashing very much. Many droplets bounce off the ground or the fluid itself. I have set the ground bounce to 0 as well as the fluid bounce.
  On 1/3/2018 at 10:03 PM, Noobini said:
this is where my FLIP experience ends unfortunately....what about adding some drag ?
Expand
didn't help :/
I also tried to increase the gravity but the result is the same...
Am I missing some contols for the fluid? Because most of the physical parameters for the flipfluidobject do not affect the simulation.
How are the pro's doing it? :D
Grabbing you file and make it a few tweaks. There is a few thing that you do not need there. First lower your particle separation and also connect both "copy parameters" on the particle fluid source and paste relative reference on the Flip OBJ so when you change it does work in FLIP as well. Also turn off reeseding particles, on the particle motion tab, you do not need it on this case.  If you want  a smooth mesh you can play with the voxel scale but also that depends of you resolution. (Btw redshift support particles, mesh and now poly soup as well). Take a look.
Milchkarton_FIX.hiplc
Milchkarton_FIX.hiplcFetching info...
Expand
Wow, thats exactly the result I wanted!
But where is the setting for "copy parameters" which you mentioned, I cannot find it :/
Same goes for the voxel scale, where is it?
Sorry if this is obvious, I'm just a beginner in the flip jungle.
Voxel scale is on the "particle fluid surface" node.
Copy parameters is just when you right click on any parameter then you will see that option then if you right click again you will see  different options to Paste your values.
Expand
Alright, thank you very very much :)
