How could I refine this interpenetration??
Hi :D I'm just studying about RBD solver and its fracturing with first picture's object.
and When I setup those with solvers (rigidbody solver and sop solver will be added),
I could find some interpenetration in it.
Those boxes were having interpenetration, so I've looking for some tutorials about it.
and I found 'Glue constrain' but that tutorial used it for fractured(and packed) object.
Does 'Glue constrain' be able to used in my situation ??
Thank you for read and always sorry for my poor English. Have a good day :D
but...this is me foolin' around again....so to test my theory, I made strength = 1 but in the sim, glueconrel, I set strength to -10000...so
-1 * 10000
or
1 * -10000
same same, they should not break...but the 2nd case does break...what gives ?
-1 * 10000
or
1 * -10000
I will have to get back to you on that, as I have not actually opened the file.
I assumed the strength is set in sops to -1?
the real test would be if you removed that multiplication factor, and just set the strength to be -1 in the glueconrel. if it still breaks then it could because the glueconrel only works with positive numbers, but as everything gets solved the mult of -1 is used. hence not triggering an error in the glueconrel
this is only a theory of a noob. Don't rely on it to heavily yet ;)
Edited by Jesper Rahlff
but that's my 2nd test above, set strength = 1 (so really if this is just a multiplier, then it's superfluous, DOP should determine the effective strength....) and then in DOP, strength = -10000...so I expect effective strength = -10000...which is infinite...but it breaks...
my deduction is this:
01) if sop strength is undefined, DOP strength works as advertised perfectly...(its sign is effective)
02) if sop strength IS defined (it is a multiplier), then DOP strength is used as MAGNITUDE only...DOP sign is ineffectual.
but if it overrides then you should be able to set strength = 1000000 in sops and then 1 in dops and it should not break?
edit: and it does not break.. so I guess it is an override.
what puzzles me though is, why if I do f@strength *= value , it still overrides and does not multiply as it should..
I'm testing if 'effective' strength is negative....is it infinite....that was my orig question
so fine if effective strength is -1 x 10000 = -10000...works
then i tested 1 x -10000 = -10000 doesn't work...
of course, the above assumes the effective strength is a product of SOP strength and DOP strength....but seems the assumption is wrong..
(no I have no interest in testing an insanely large positive number to see if it breaks, i'm testing a negative number that should NOT break)
I can see in the spreadsheet that in SOP land, it is set to say -1.0....but in DOP land, the GlueConRel is its own value, say 10000...so I cannot find anywhere that it is a 'product' of -1x10000....but....it is also not being overridden by the -1 !!!
