Hey guys,
I'm relatively new to the awesomeness of Houdini.
I'm into destruction as an area of the effects field more than I'm into fluids etc.
I've a little school/hobby project I'd like to develop, but I'd like some pointers before I begin!!
I want to build a brick tunnel which will collapse. (the modelling shouldn't be difficult ;)). But I'm wondering more about the destruction side. Should I make a basic poly tube, halve it etc. Or should I make something that's procedurally created with bricks? I'm thinking of doing some kind of FEM sim, rather that voronoi, so I wondered how it's modelled would effect how it's simmed?
I'm looking to build something like this:
I was thinking of applying a similar technique to this discussion:
Or is that just wasting time and resources and it's better off to simply texture it?
I'd love some ideas before I embark on it!!
Thanks
Addy
Noobini, thanks once again!!
What I meant by FEM and bricks is more would a simulation be effected if I modelled using this compared to having, say, a polygon tube? ie, is it more accurate to build something like what you've attached, or it doesn't matter?
not on a machine atm but in the bend, you can manipulate the capture length until it bends the whole length instead of leaving a straight section...ie. bend all the way and you get a tube
Actually, that's controlled by Bend on the CTRLS, so just dial it up, about 17, you get halfpipe, then simply mirror it in Y axis...that's the quickest method
Edited by Noobini
1 hour ago, AddyJ said:
How'd I wrap that around something like a Tube?
// CONVERT PLANE TO CYLINDER
vector bbox = relbbox(0, @P);
@P.x = sin(@P.x * $PI * 2);
@P.z = bbox.y;
@P.y = cos(bbox.x * $PI * 2);
https://www.sidefx.com/forum/topic/48058/
Also google for cartesian to cylindrical coordinates.
