Offset Carve SOP Growth
JAMES2503
So I have a few curves (in attached GIF) and they all start at the same time and grow using the carve SOP.
I'd like them all to start at different times but from their original positions, (no randomness) just a simple offset.
I don't want to do it for each curve manually, is there an expression I can use?
Brilliant, just what I was looking for! Cheers!
Just a quick question, in my carve SOP, I have the expression: @Time/7 - detail(-1, "iteration", 0)/18.5
This generates a nice growth but I want it to have bezier like smooth interpolation between the start and end points, how would I add this to the expression?
Edited by JAMES2503
wrong expression, oops
Hi , Jim!
Actually , there is a function in houdini's include files.   it's called adjustPrimLength.
so, what you need to do is , in a primtive wrangle, call the function ,like below:
the nice thing is , each curve can has a different f@dist attribute , so they can grow differently.  Code like this : adjustPrimLength(0, @primnum, @perimeter, @perimeter*@dist);
Thank Pangzi, appreciate the input.
Got another question (yes I'm newish to Houdini)
I need a solution to push intersecting wires away from each other. I have both the curves and polywire setup, I thought of a solution in VOPs but it didn't quite work.
See below, cheers guys
