Scatter points on a side of geometry only
I have a thin rectangular box for example and I had wanted to use the Scatter node.
However it appears that the points generated is appearing on almost all the faces. Is it possible to 'guide' the Scatter node to generate points on a side that I wanted, without have to blast off all other faces?
3 hours ago, toadstorm said:
he did mention he didn't want to blast all the other primitives, though that would be my preferred workflow in this case.
well yeah i read that but thought...yes can be a 'bit' fiddly selecting the prims to blast...while clip is just so simple to use...hence I suggested it, that's all.
