larklee Posted November 5, 2002 Share Posted November 5, 2002 i just started playing around with houdini and i would like to know if there is a command line to render ( similar to maya ) Quote Link to comment Share on other sites More sharing options...
danteA Posted November 5, 2002 Share Posted November 5, 2002 You will notice if you look at the parameters for a Mantra Output operator, that there is a "Render Command". Inside, by default it says "mantra". If you click on the plus button, then it gives you various command line options for mantra. Typically, to do command line rendering, you turn on "Generate Script File" which produces an .IFD file which is similar to the renderman .RIB script file. You can then pass this .IFD file to mantra for rendering. However, the option for generating script files seems to be disabled on my Houdini Apprentice. Quote Link to comment Share on other sites More sharing options...
stu Posted November 5, 2002 Share Posted November 5, 2002 Here's a standard one: hrender -e -v -f 1 1 -i 1 -d mantra1 file.hip -e (can't remember, but you need it!) -v (verbose) -f (frame range) -i (frame increment) -d (output driver) file.hip (filename) stu Quote Link to comment Share on other sites More sharing options...
larklee Posted November 6, 2002 Author Share Posted November 6, 2002 i tried that command above: hrender -e .... mantra 1 at the command line tools under windows and it prompted 'hrender' is not a valid command, ...i'd run it at hscript and it prompted 'unknown command'..am i missing something here? Quote Link to comment Share on other sites More sharing options...
plan9 Posted November 6, 2002 Share Posted November 6, 2002 greets, make sure you have sourced houdini_setup within the cshell, otherwise you will get the unknown command error mantra -h will give you all the render flags and a brief explanation of what they do. Quote Link to comment Share on other sites More sharing options...
Andy_Ireland Posted May 9, 2013 Share Posted May 9, 2013 (edited) Using latest Houdini Apprentice HD on Mac OS 10.6.8, get as far as "Entered non-commercial session mode" and then "Can't fine node /out/mantra1" Anyone any ideas what is going wrong here? Edited May 9, 2013 by Andy_Ireland Quote Link to comment Share on other sites More sharing options...
ryew Posted May 9, 2013 Share Posted May 9, 2013 "Can't fine node /out/mantra1" Hard to say without seeing what's in your scene - do you have a mantra1 node in your /out context? Quote Link to comment Share on other sites More sharing options...
Andy_Ireland Posted May 9, 2013 Share Posted May 9, 2013 Ryew, I was trying Stew's sample and ran ito the problem, I was using something like this on Linux last year but don't remember having to type mantra. I have tried a few different things now and still getting basically the same error: "couldnt find renderer mantra" Quote Link to comment Share on other sites More sharing options...
goldleaf Posted May 10, 2013 Share Posted May 10, 2013 I use hbatch usually. Sometimes hython, to get a little bit more control. Here's an example: https://gist.github.com/crydalch/3167162 You just need to make sure your houdini environment is all setup, or you're running from the Shell/Commandline shortcut in the Houdini install folder. Quote Link to comment Share on other sites More sharing options...
Andy_Ireland Posted May 11, 2013 Share Posted May 11, 2013 Thanks goldleaf, Ill try it out Quote Link to comment Share on other sites More sharing options...
ryew Posted May 12, 2013 Share Posted May 12, 2013 I was using something like this on Linux last year but don't remember having to type mantra. I have tried a few different things now and still getting basically the same error: "couldnt find renderer mantra" It works for me using hbatch and render commands in 12.5.316.22 NC on Ubuntu linux: > source houdini_setup_bash > hbatch /var/tmp/renderTest.hipnc hbatch Version 12.5.316.22 (Compiled on 03/13/13) WARNING: Entered non-commercial session mode. / -> render mantra1 http://www.sidefx.co....5/render/batch lays out all the various stages and command line options renderTest.hipnc Quote Link to comment Share on other sites More sharing options...
