nicoladanese Posted May 16, 2018 Share Posted May 16, 2018 Hey! I'm scattering some points and then use them as first input in a popnet to sim it. in the pop source I'd like to just emit a point for every source point, so basically I'm emitting for 1 frame with the same number of points, to get the same points in the sim. is there a way to tell the pop source to emit the exact number of points you have as input (at the mo I'm just manually putting the number...) ? cheers! Quote Link to comment Share on other sites More sharing options...
Skybar Posted May 16, 2018 Share Posted May 16, 2018 Set the emission type on the pop source to "all points". Quote Link to comment Share on other sites More sharing options...
nicoladanese Posted May 17, 2018 Author Share Posted May 17, 2018 hey thanks for your reply! right, but what about the impulse count? I was looking into something like an expression to tell the impulse count how many points I'm feeding into the pop source... Quote Link to comment Share on other sites More sharing options...
3dome Posted May 17, 2018 Share Posted May 17, 2018 you can use npoints(opinputpath("..", 0)) if you have the sourcepoints plugged into first input still, I'd go with what Skybar said and use "All Points" Quote Link to comment Share on other sites More sharing options...
macj89 Posted May 17, 2018 Share Posted May 17, 2018 Here you are! Make your geo. Scatter some points. make a popnet set it to all points. set the frame you want to emit, only for 1 frame ($$FF==1) for example. You have instructions inside the hip anyways. Have fun! popnet_sourcingPoints.hiplc Quote Link to comment Share on other sites More sharing options...
nicoladanese Posted May 18, 2018 Author Share Posted May 18, 2018 thanks guys! I think opinputpath was the command I was looking for! thanks for the hip Miguel! Quote Link to comment Share on other sites More sharing options...
