Sweep individual section length for each curve.
I can not replicate the setup... how spare_input_0 connection was done?
Why are you promoting attribute to detail? Point attribute would not work?
What does -1 means in detail() expression?
Edited by kiryha
14 minutes ago, kiryha said:
Cant replicate the setup... how spare_input_0 connection was done?
select some node, Gear icon (next to the big H)>Add Spare Input
well you'd want prim or primattrib coz there's only 1 width for a 'curve' (prim)...not different widths for each point. I did try prim/primattrib first but couldn't get it to work...so for each iteration, I promoted the width attr to detail (a curve)...then interrogate the detail width
in a node you see in/out ports (the circles)...the order is 0, 1, 2, 3....99% of the time you'd use 0 as it is the 1st input. For Spare Inputs...they go to the left...ie -3, -2, -1...so in the transform, the default port is 0, the first Spare Input is -1 (an imaginary port to the left). You can use "../blah blah" instead of -1 too (the blah blah is what's in the Spare Input 0 field)
ok so for the hell of it... I changed prim(opinputpath(".", 1), $PATH, "stripWidth", 0)
to prim(1, $PATH, "stripWidth", 0)...works..
Don't understand the $PATH bit tho...can someone pls explain ?
Ahhh...got it...this one:
prim(surface_node, prim_num, attrib_name, attrib_index)
(expression function...not VEX function)
But how does $PATH equate to prim 0, 1, 2 ...etc... ?
Edited by Noobini
Thanks, guys, the Victor solution is rocking also!
Although I have some issues with my curves sometimes and I don't understand why some of them picking up wrong values:
Also, I was not able to get this attribute value in polyexpand2d2 SOP...
ROADS_003.hipnc
Edited by kiryha
1 minute ago, kiryha said:
How to decide when use point attributes, and when primitive? At previous example we used primitive, now switch back to points...
Yes, now i use point attr, but then i promote this attribute back to prim attr.  How to decide which attr use? It depend which attribute use node. Some node use point attr some prim attr and some detail attr. Need to look to help card for node
Still not able to get polyExpand2D working. Is it because Offset parameter required another then primitive type of the attribute?
I try to use point attribute with an expression point('../attribpromote2',0, "rWidth", 0), it works, but all curves have the same amount of offset...
ROADS_004.hipnc
Edited by kiryha
Expression was not right. There is some problem in geometry with one of the line before foreach loop and polyexpand2d has error. Hip file in attach so far. And i presume you need to connect lines as in network box in the scene but i not understand actually what you try to achieve with polyexpand2d.
ROADS_004_01.hipnc
Thanks, Victor! With  polyexpand2d I build paths for the vehicle's motion.
Now I am thinking how to clone cars with time shift and the only way I know is export car animation to Alembic and clone it with a time shift (as Tomas described here)
This technique works perfect but I am not sure if its a best solution for this task.
Edited by kiryha
Hi, Vusta!
That solution with resampling and smooth also come to my mind and it works well.
So now I need to clone a bunch of cars along a bunch of paths... but this question is far away from the original topic...
