kiryha Posted May 22, 2018 Author Share Posted May 22, 2018 (edited) Instead of Alembic, I use Carve + Sort to animate cars along paths within for loop . Works well. But then I tried to randomize vehicle models with one more loop and switch node — I lost my car orientations along the path (from up_vector node). I know that is because of attributes lost but can't wrap my head how to fix it. If you bypass FEB_VARIATIONS and FEE_VARIATIONS nodes it will work with orientations. ROADS_OD_006.hipnc Edited May 22, 2018 by kiryha Quote Link to comment Share on other sites More sharing options...
Atom Posted May 22, 2018 Share Posted May 22, 2018 It looks like your Alembic's are hosed. They unpack to zero polygons. Quote Warning Geometry contains degenerate primitives Quote Link to comment Share on other sites More sharing options...
kiryha Posted May 22, 2018 Author Share Posted May 22, 2018 It could be any object, not necessary alembic. I substitute ABC with platonic, although it's hard to see they are not aligned to the path, that's why wired scale applied. ROADS_OD_007.hipnc Quote Link to comment Share on other sites More sharing options...
Noobini Posted May 22, 2018 Share Posted May 22, 2018 not quite sure about your polyframe...so I replaced with a 'usual' one... ROADS_OD_007_mod.hipnc 1 Quote Link to comment Share on other sites More sharing options...
kiryha Posted May 24, 2018 Author Share Posted May 24, 2018 (edited) Is it possible to get a path for traffic with poliexpand2D if the source curve is not flattened but bent (like a bridge)? Or I have to do it in the flattened curve and deform it after? bridge_001.hipnc Edited May 24, 2018 by kiryha Quote Link to comment Share on other sites More sharing options...
Noobini Posted May 25, 2018 Share Posted May 25, 2018 back to the good ol' sweep ? vu_undulatedPath.hipnc 1 Quote Link to comment Share on other sites More sharing options...
kiryha Posted May 25, 2018 Author Share Posted May 25, 2018 Great! Let it be the Sweep! On curves which were build in Houdini that way works fine. On the curves reconstructed from Maya polygons - no, but this is not an issue. Here is the scene if anybody will need it: - Attach several cars to follow any number of input paths - Normalise cars speed for different paths length - Randomize car location on paths - Control cars orientation with VEX ROADS_007.hipnc Quote Link to comment Share on other sites More sharing options...
