UV Flatten node bugged?
Jesper Rahlff
Hey guys.
I need someone to take a look at my scene and tell me why it keeps crashing using the UV Flatten node.
I have in the file a working example, and then a non-working one.
there is only a few operations in difference between the to uv flatten setups, however one of them is not working. Any help, or confirmation that this is in fact a bug and not just me overlooking something, is appreciated.
Cheers
Hershey_mod_v0010_workinguvs_jra_.hiplc
01) if you disable the sort, it works
02) now reenable the sort it will crash if you sort only the points
03) if you also sort the prim by same method, prox to point...it works....
don't ask me to explain...coz I wouldn't know how to...
ok, so if I reverse point sort...it works....if I now apply the same logic to the create_groups....ie. I swap start/end groups...it again crashes therefore the sort is not agreeing with your create_groups somehow...
