[SOLVED] Offseting points on curve
Hey magicians,
I've got an alembic walk cycle cloned on a curve that I need to offset the points in order to make them look like walking forward, its probably a dumb question but I can't figure out how to offset the points. Line sop has offset so I thought I can just deform this with a noise and offset that, but how can I offset points on a hand made curve like this?
Something like this
Thanks!
Edited by caskal
1 minute ago, ikoon said:
Hi Ezequiel, I did a similar version long time ago. Not a best solution today (we dont copystamp now), but it may help you in a way, if nobody else has better solution:
https://forums.odforce.net/topic/27665-multiple-objects-along-curve-aligned-to-curve-solved
Thank you @ikoon that gif looks great, will study the file!
Also Matt Stela gave me this link via Facebook in case someone else had this doubt
http://www.tokeru.com/cgwiki/index.php?title=Houdini#Slide_points_along_edges
Cheers!
  • Thanks 2
