Scatter Piece attribute ?
Quote
The name of a partition attribute defining pieces, where each point/primitive where the attribute has the same value is considered part of the same piece. Several tools such as Shatter create this type of attribute for you. If not given, the node will simply loop over every point/primitive in the input. Not available in repetition mode.
Partition attributes can only be integer or strings. This will be a point or primitive attribute depending on the value of Piece element.
Shatter not scatter.
  • Haha 1
