Tree RIG Sway In Wind?
Atom
I have this FBX import of a tree rig with FK bone setup. Is there some way to make the tree sway in the wind automatically? Or convert this to some kind of spring based rig?
Is there a way to convert bones to curves so I could use this in a wire solver perhaps?
Edited by Atom
I was able to output the tree as curves only. But I only have the points for the curves, not individual primitives yet. If I could construct primitives from the points I might be able to perform some wire operations upon the tree.
I have some detection code, based upon neighbor count, but it is not really working right. Does anyone have an idea on how to detect the individual branches from a point cloud? Basically I am trying to create an i@id for each branch so I can use the Add node to make each line.
Edited by Atom
By measuring the distance between the current and the next point I have been able to reliably detect most branch end points. Now to figure out starting points...
// Get the number of points.
int npt = npoints(0);
// Loop through the points minus 1.
for(int i = 0; i < npt-1; i++) {
    // Get the distance to the next point.
    vector p1 = point(0,"P",i);
    vector p2 = point(0,"P",i+1);
    float dist = length(p2-p1);
    if (dist>ch("threshold")) {
        // This may be an end point.
        setpointattrib(0, "Cd", i, {1,0,0}, "set");
    } else {
        // In between point.
        setpointattrib(0, "Cd", i, {1,1,0}, "set");
    // Set the distance to next point.
    setpointattrib(0, "dist", i, dist, "set");
Coming full circle, now that I have curves, I can use the Bones from Curves shelf tool to create a bone chain along the curve. But the tool only works on the first primitive.
Is there a way to make the tool run multiple times for each primitive?
Could I python exec() the tool, in a loop, and fake out kwargs?
Edited by Atom
