macj89 Posted October 11, 2018 Share Posted October 11, 2018 Hi guys! I was wondering if i could use a portion of the $HIPNAME (scene name) to name my renders. Example: SH001_mountain_v1.hip So, what I want, is my render file name look like this: SH001_mountain_$OS_v1_$F4.exr So, basically we are looking a way to extract the first 14 characters from the $HIPNAME aswell the last 2 characters (version number). I know it's posible with Python but i am trying to avoid it, since we tried and it gave us a lot of errors (we are not coders). Is this thing posible with Hscript or should i go deep into python? Thank you very much guys! Quote Link to comment Share on other sites More sharing options...
StepbyStepVFX Posted October 11, 2018 Share Posted October 11, 2018 (edited) You can try doing it in VEX, putting $HIPNAME in a parameter, create a string variable initialized with chs("ref_to_your_param"), and then use the split function on this variable (and other VEX functions on strings), to keep the parts that you want, and use sprintf to concatenate the full path you need, and then putting that into an attribute at detail level. Then create another parameter on your Wrangle, in which you will use detail() to get the path into the parameter, that you can reference on your mantra node inside the image filename. Alternatively, in this case, I am wondering if you could use substr() : `substr($HIPNAME, 0, 15)`$OS_`substr($HIPNAME, 16, 2)`_$F4.exr Try it and let us know Edited October 11, 2018 by StepbyStepVFX 1 Quote Link to comment Share on other sites More sharing options...
lukeiamyourfather Posted October 16, 2018 Share Posted October 16, 2018 A consistent and user friendly way of doing it would be to add something to the $HSITE launch scripts (123.py, 456.py) where it takes the scene file name and creates a new variable like $HIPBASE that excludes the version number. Then use that variable in the file name rather than screwing around with expressions on the parameter. 2 Quote Link to comment Share on other sites More sharing options...
macj89 Posted October 16, 2018 Author Share Posted October 16, 2018 (edited) I am not a good coder and i am having a really hard time with this thing. I already had a bad time with python and I was trying to get a solution via the normal hscript. So, where am I now: 1. My $HIPNAME is this one: SEQ_SH0000_globalfx_v001_mac 2. I create a $RENDER global variable, non procedural, because this folder has to be on the same level of $HIP but I don't know how to set up procedurally haha 3. Following @StepbyStepVFX advice, i wrote this down: $RENDER/`substr($HIPNAME, 0, 11)`${OS}/`substr($HIPNAME, (abs(strlen($HIPNAME))-8), (abs(strlen($HIPNAME))-4))`/`substr($HIPNAME, 0, 11)`${OS}_`substr($HIPNAME, (abs(strlen($HIPNAME))-8), (abs(strlen($HIPNAME))-1))`.$F4.exr It should be giving me this naming: ..../render/SEQ_SH0000_object_task/v001/SEQ_SH0000_object_task_v001_mac.1001.exr but it is giving me this: ..../render/SEQ_SH0000_object_task/v001_mac/SEQ_SH0000_object_task_v001_mac.1001.exr So, I got it almost! I just have to get rid of that _mac that is not working as expected, is like the STRLEN is not detecting properly the character numbers for v001_mac , i can get rid of the v001 but i can't get rid of the _mac. `substr($HIPNAME, 24, 28)` gives me _mac `substr($HIPNAME, 20, 24)`gives me v001_mac instead of v001, that it doesn't make any sense. Thanks guys! I will get into that $HSITE thing, its the first time that i hear that! haha *attaching the hip SEQ_SH0000_globalfx_v001_mac.hiplc Edited October 16, 2018 by macj89 Quote Link to comment Share on other sites More sharing options...
pxptpw Posted November 19, 2018 Share Posted November 19, 2018 (edited) so from combing through other similar posts , from lukeiamyourfather post on this topic , houdinitricks.com/create-custom-global-variables-houdini/ and mainly sidefx content help for ex : your scene name = blah_some_someotheting_v016 so when you have the 123.py or 456.py from the scripts folder , and your python hou module in either one of those import hou hou.putenv("VERNAME", hou.expandString("$HIPNAME").split("_").pop()) and when you restart houdini , in the textport echo $VERNAME it would return the version number v016 hope this help anyone looking for this Edited November 20, 2018 by pxptpw Quote Link to comment Share on other sites More sharing options...
