SciMunk Posted October 12, 2018 Share Posted October 12, 2018 Hi all! I was playing with the vellum solver and it just awesome ! there a feature I just couldn't find, maybe it just not present, I was wondering if it possible to recreate it : the cloth target deformation, which force the simulated shape to try to match the specified geo shape, I tried to use a pop attract in the dop, without much success any idea ? thanks ! Quote Link to comment Share on other sites More sharing options...
anim Posted October 12, 2018 Share Posted October 12, 2018 if you set Pin to Target constraint to Soft, then you can control the strength by Stretch Stiffness (for soft position type) and Bend Stiffness (for soft orientation type) it's also present within cloth/hair constraints where it's called Pin To Animation if you however want just shape changes and not necessarily constraint your geo to a specific locations you should use Vellum Rest Blend SOP or DOP which allows you to update rest state of the constraints and therefore force your vellum object to try to assume that shape Quote Link to comment Share on other sites More sharing options...
Atom Posted October 12, 2018 Share Posted October 12, 2018 What more would I need to add to leverage this blend feature? I am trying to make the pig blend into the squab. Quote Link to comment Share on other sites More sharing options...
anim Posted October 13, 2018 Share Posted October 13, 2018 (edited) it's for blending rest attributes of the constraint geometry using the geometry of the third input (or provided SOP if using DOP version) literally serves the same purpose as FEM's or Wire's Rest Geometry so to morph pighead to squab it would require both to have the same topology and you 'd need to have some constraints (like cloth) on the pighead already, then plug first 2 outputs of the vellum constraint to vellum rest blend and squab to the third, then you can tweak how much the constraint rest attributes will try to match the squab shape (again, has to have the same topology) to blend over time you may want to use DOP version sorry, cant post file, don't have access to H17 at the moment Edited October 13, 2018 by anim Quote Link to comment Share on other sites More sharing options...
SciMunk Posted October 15, 2018 Author Share Posted October 15, 2018 (edited) Thanks for the answer anim, I tried to use the pin to animation, but it very hard to control the strength using the stiffness, it either start to fly away after getting a collision, or the deformation do not affect the neighbour point. the effect I want to reproduce is this : http://share.scimunk.com/2018-10-08_15-22-49.mp4 which I made using the default cloth solver. on this effect, the upper border are fully constrained using a targetStrength of 100000, and gradually decrease at the center to permit movement. Edited October 15, 2018 by SciMunk Quote Link to comment Share on other sites More sharing options...
anim Posted October 15, 2018 Share Posted October 15, 2018 can you post the scene? Quote Link to comment Share on other sites More sharing options...
moreffects Posted January 25, 2019 Share Posted January 25, 2019 @anim I have tried the steps you mentioned to blend shape from pighead to squab, no luck, do you mind showing example? Quote Link to comment Share on other sites More sharing options...
Noobini Posted January 25, 2019 Share Posted January 25, 2019 (edited) not sure what the big deal is with the effect...here's a very basic setup. vu_VellumTube.hiplcFetching info... Edited January 25, 2019 by Noobini Quote Link to comment Share on other sites More sharing options...
moreffects Posted January 25, 2019 Share Posted January 25, 2019 thanks for the effort noob .but this is not what I'm talking about. I'm trying vellum cloth to be blend to another static shape or wrapping to static shape. Quote Link to comment Share on other sites More sharing options...
Noobini Posted January 25, 2019 Share Posted January 25, 2019 well I'm replying to Scimunk, the OP, check his reference....tell me if that's not the same effect. if you want to hijack the thread....simply create another one that clearly states your intent. 1 Quote Link to comment Share on other sites More sharing options...
