Orient packed primitives to velocity
Farmfield
This is immensely annoying, haha... So I set this up like 3-4 years ago in H14, but I can't for my life seem to recreate it today. I thought it would be as simple as calculating a matrix from the velocity and then using setprimintrinsic to transform to that matrix - but I just can't get it working. Any ideas?
Oh, and I'm not at all excluding that I did the above using something way simpler, like using some POP node - that's maybe even more likely than me doing it in a VOP or using VEX...
  • 4 weeks later...
  On 12/4/2018 at 1:07 AM, toadstorm said:
wouldn't it be more straightforward to use `maketransform(v@v, v@up)` rather than computing a dihedral that rotates one vector onto the other?
i mean if it works, it works... just seems like an unusual approach.
I do non straightforward stuff using unusual approaches all the time, funny enough. It served me well. ;)
  On 11/30/2018 at 4:17 PM, dyei nightmare said:
diedral?   im interested on how you used diedral for this case.
The scene file is linked in the video - and Toadstorms code works as well, and it's one line instead of two, haha...
