Vellum Part Of A Character?
Atom
Hey Atom, I can't make some screenshots now but here's what i'd do:
if the vellum points have an attribrute i@stopped = 1 and other attribute i@gluetoanimation = 1  it will make this points follow the original geometry. If it's 0 in both it will be simulated. Not sure if you have to enable it on the vellum constraints in sops as well
  • Thanks 1
Thanks for the tip ParticleSkull, here is a basic setup working using those two attributes you mentioned above.
// Setup attributes based upon color paint value.
i@stopped = 0;
i@gluetoanimation = 0;
if (@Cd.r==0) {
    i@stopped = 1;
    i@gluetoanimation = 1;
I am wondering if some kind of strut constraint might help the trunk keep it's volume better?
Edited by Atom
It looks like more Constraint Iterations helps a lot to remove the floppy effect, here I have raised it from 100 to 300.
I also added in a Struts constraint and turned the Stiffness up from 100 to 1,000. The green spheres are produces by the visualizer in the post process node. I lowered the Thickness on the initial vellumcloth1 node while keeping an eye on the size of the green spheres. Make sure the green spheres don't overlap each other.
Edited by Atom
 great, but whats your set up regarding your skeleton joints?  or are you appling this on a baked animated geometry? i guess?
Edited by dyei nightmare
