MadMax50 Posted December 30, 2018 Share Posted December 30, 2018 Hello, I have a small problem regarding a slow viewport in Houdini. When I zoom close to a pyro simulation and try to pan around it, the viewport will be noticeably slow and laggy. This would make sense if I had a basic graphics card but I am currently running on the NVIDIA Quadro M5000 graphics card with (8gb vram). I also have a dual monitor setup: 4K 32 inch and a HD 27 inch . I know that the 4k monitor would require more power to run but I thought that the quadro m5000 would handle it no problem. The rest of my machine is a dual xeon setup with 64 gb of ram. So overall it's a very powerful machine that should handle houdini viewport no problem but it doesn't seem to at all. and yes I have already updated the graphic card drivers. Would love to hear any thoughts. Thank you! Quote Link to comment Share on other sites More sharing options...
malexander Posted January 7, 2019 Share Posted January 7, 2019 Volumes are rendered as many parallel planes blended together, so if the number of pixels in the viewport is large and it's a large volume (or several), you're probably maxing out the GPU's ROPs which do the framebuffer blending and writes. You can try adjusting the volume quality and/or size in the Geometry and Texture tabs of the display options. Quote Link to comment Share on other sites More sharing options...
lukeiamyourfather Posted January 11, 2019 Share Posted January 11, 2019 Adjusting the volume resolution in the display settings can make a huge difference. The Quadro M5000 is on par with a GTX 970. It's not a bad card but it's not a 4K-with-high-resolution-volume-at-high-frame-rate kind of card. Quote Link to comment Share on other sites More sharing options...
animatrix Posted February 8, 2019 Share Posted February 8, 2019 You can also set volumes to display as points in wireframe. I saw serious speed ups in this mode. Quote Link to comment Share on other sites More sharing options...
