Mozzarino Posted January 15, 2019 Share Posted January 15, 2019 I am trying to recreate this effect, and I can't find any info on how this techniques were implemented… Any help ? Thanks, Diogo Quote Link to comment Share on other sites More sharing options...
merlino Posted January 15, 2019 Share Posted January 15, 2019 You can try putting "pressure" as the control field for your turbulence. Then you can work with the ramp so you can control where it will be working (high pressure or low pressure areas). Visualize it so you'll have a better visual feedback to understans what's happening. Cheers! 2 Quote Link to comment Share on other sites More sharing options...
Mozzarino Posted January 15, 2019 Author Share Posted January 15, 2019 @merlino worked like a charm! thanks alot Quote Link to comment Share on other sites More sharing options...
merlino Posted January 15, 2019 Share Posted January 15, 2019 Happy it worked! Remember you can always MMB over the pyro/smoke solver (starting from the 2nd simultation frame in most cases) and see which fields you already have to work with. 1 Quote Link to comment Share on other sites More sharing options...
Mozzarino Posted January 16, 2019 Author Share Posted January 16, 2019 @merlino once again, thanks for the valuable info! I'll share a more advanced setup I managed to create by diving a bit deeper: In SOP level I assigned float values to points and created a vdb from points with said "mult" volume primitive. Then I used the sopscalarfield node to read those values and in the gasfieldwrangle I multiplied my "press" scalar field (created by copying the values of the pressure field) with the "mult" scalar field values. This way, I can use "press" field as a control field for any gas force such as disturbance... And the "mult" field serves as a mask for the "press" field. Watchout for the "Default Operation" default value, as it is "Set Initial" and, in case you have an animated volume you may want to swap to "Set Always". Otherwise it won't update the field. 1 Quote Link to comment Share on other sites More sharing options...
