Andrea Posted January 21, 2019 Share Posted January 21, 2019 Hello! I am creating a python script that search for all the textures used in the project and copies them in a folder $HIP/textures. After that, it converts the path to $HIP/textures/[texture_name]. It works fine until there isn't a variable like $F in the string. If this is the case, it copies just the first frame and not the full sequence. What I am using to collect all the textures path is a line from a code I've found: files = glob.glob(hou.expandString(re.sub(r'\$F\d', "*", parm.unexpandedString()))) Being a python newbie, I am not really sure to correctly understand what it does in order to fix this issue. I got more or less that re.sub replace the first argument (\$F\d) with the second argument ("*") inside the text of the third argument. Is all the expandString and unexpandedString that confuses me. Seems like that this function just returns the string value at the current frame? What if I want to get all the textures/files? Thanks in advance for any help/suggestions Quote Link to comment Share on other sites More sharing options...
Atom Posted January 21, 2019 Share Posted January 21, 2019 Check out this doc page. You might try replacing unexpandedString() with rawValue()? http://www.sidefx.com/docs/houdini/hom/hou/Parm.html Quote Link to comment Share on other sites More sharing options...
Activate Posted January 21, 2019 Share Posted January 21, 2019 (edited) Do you have examples where this does not work? The regular expression replaces occurrences of $F4, etc with *. The * is a wildcard for globbing for matching files in the filesystem. expandString does all the Houdini magic to turn the expression into a complete path. If your path just contains file.$F.png, the regular expression above will not match and then expandString will substitute the frame number, i.e. you only get the first frame. Try to use r'\$F\d?' instead. Edited January 22, 2019 by Activate Quote Link to comment Share on other sites More sharing options...
Andrea Posted January 22, 2019 Author Share Posted January 22, 2019 (edited) Hello! Thank you guys. So using the question mark r'\$F\d?' as @Activate suggested, did the trick to collect the sequence of textures and copy them to the destination folder. Using rawValue() returns the path I want. For one moment I think the script worked and it returned also the right string. In the happyness of the moment I started to change some other lines and.. is not working anymore as expected. It doesn't return the correct string with $F4 as before. Anyway right now I have added a line that searches for the last / and uses it for strip off the texture name. Now I would like to improve it and understand it better. I post it here as it is right now but please be aware that it copies all the referenced files and not just the textures. import re, glob import hou, os, shutil ### SET and CREATE PATH FOR TEXTURES #### folder_name = "textures" hip_path = hou.getenv("HIP") backpath = hip_path + "/" + folder_name #change this name for change the folder name if not os.path.exists(backpath): os.makedirs(backpath) print "created directory for textures" ### for DEBUG PURPOSES ### # print backpath ### SINCE I SCRIPTED THIS AND I DONT TRUST MYSELF; BETTER DO A BACKUP HIPFILE #### hou.hipFile.save() hou.hipFile.saveAndIncrementFileName() #### MAIN FUNCTION def BackupAllContent(inputpath): # look for all the nodes subch = hou.node("/").allSubChildren() # start loop for all the nodes for child in subch: # takes all the parameters of the node parms_in_nodes = child.parms() # loop over all the parameters for parm in parms_in_nodes: # IF the parameter is a type string if parm.parmTemplate().type() == hou.parmTemplateType.String: syc_test = "" try: ##nodes with something inside else are skipped syc_test = glob.glob(hou.expandString(re.sub(r'\$F\d?', "*", parm.unexpandedString())))[0] except: pass if os.path.exists(syc_test) and parm.eval() != "*": ###print parm ## DEBUG parameters and nodes with link to external geo files = glob.glob(hou.expandString(re.sub(r'\$F\d?', "*", parm.unexpandedString()))) for fls in files: if os.path.exists(os.path.join(backpath, os.path.basename(fls))): print os.path.basename(fls) + " is already there" ## DEBUG textures name else: shutil.copy(fls,backpath) print os.path.basename(fls) + " has been copied" raw_texturename = parm.rawValue() texturename_variable = raw_texturename[raw_texturename.rfind("/")+1:] new_texture_path = os.path.join("$HIP/", folder_name, texturename_variable) ## merges this names/directories in one string based on operator system syntax new_texture_path = new_texture_path.replace('\\','/') ##since I am on windows I have to convert \\ to / parm.set(new_texture_path) #set new path print "#################################################" print "new texture path would be " + new_texture_path print "raw value is " + parm.rawValue() print "unexpandedString is " + parm.unexpandedString() print "re.sub is " + re.sub(r'\$F\d', "*", parm.unexpandedString()) print "expanded string is " + hou.expandString(re.sub(r'\$F\d?', "*", parm.unexpandedString())) print "texturename_variable is " + texturename_variable print "#################################################" ### RUN CODE ## BackupAllContent(backpath) Edited January 22, 2019 by Andrea mistake Quote Link to comment Share on other sites More sharing options...
kramer3d Posted January 30, 2019 Share Posted January 30, 2019 If you only have to deal with $F then you may consider using hou.expandStringAtFrame() instead. Quote Link to comment Share on other sites More sharing options...
