HM_2020 Posted February 14, 2019 Share Posted February 14, 2019 Hey fluid masters, is it possible to combine 2 Particle Fluid Surface nodes? I am getting better "gloop" and tension in the meshing of 2 different sims using PFS. VDBs, not so much. Even using VDB to Particle Fluid Surface is not as good as PFS. See where it simply Boolean Unions and doesn't Mesh them together like the Particle Fluid Surface node? Cheers! Quote Link to comment Share on other sites More sharing options...
Skybar Posted February 14, 2019 Share Posted February 14, 2019 Not sure what you mean, Particle Fluid Surface uses VDBs internally. You can choose to output VDBs from the Particle Fluid Surface and combine them afterwards if you'd like. 1 Quote Link to comment Share on other sites More sharing options...
HM_2020 Posted February 14, 2019 Author Share Posted February 14, 2019 (edited) I have two sims... the main tube, its low res sim, not many particles, so to PFS mesh it, I need certain large pscale, Influence, all the settings in PFS to get a nice shape. The high drops, separate sim, needs its own PFS settings to get a nice "crown splash drops" style and keep the high res. If I merge the 2 flip particles sims, and then use one PFS node, where they meet "gloops" and has tension in the mesh, looks really nice, but alas the Core shape looks messed up like balls since it has different settings. So I thought I could use one PFS node for each sim (core gets larger pscale, influence, etc, drops get lower everything etc), and then simply do one last merge, and they would gloop together. But sadly that just merges them without even a Union.... Next tried VDBtoParticleSurface Nodes for each sim, then did VDB Combine, which results in the image above... boolean union but again no good gloopy meshing where the drops suck out of the core. So basically I need to have 2 separate PFS nodes, and then I guess somehow do one last meshing of those two, where points merge into metalball style gloop. Ya get me? Edited February 14, 2019 by HowardM Quote Link to comment Share on other sites More sharing options...
ejr32123 Posted February 14, 2019 Share Posted February 14, 2019 Can't you just use 1 particle fluid surface node and use point attributes on the different meshes to get different settings? Also what skybar said. You can just output vdbs from the particle fluid surface node and combine them together. The vdb it outputs would be identical to mesh it would output. 1 Quote Link to comment Share on other sites More sharing options...
HM_2020 Posted February 14, 2019 Author Share Posted February 14, 2019 Hope this helps make sense of what I am asking. Quote Link to comment Share on other sites More sharing options...
HM_2020 Posted February 14, 2019 Author Share Posted February 14, 2019 Silly me, I forgot to use a VDBreshape to "gloop them together", which as you can see in 2nd image is working where the particles meet. Now the issue is, how do I make this only happen only where the points/mesh meet, not all the drops away from the core as I lose their detail. Cheers! Quote Link to comment Share on other sites More sharing options...
Dave Stewart Posted February 14, 2019 Share Posted February 14, 2019 Howard, here's how I would do it. Take your 2 VDBs, dilate them, VDB Combine using SDF Intersection, then convert the result to a Fog VDB and plug it into the 2nd input of the final VDB Smooth node. Should mask the regions that you don't want smoothed. Throwing together a quick'n'dirty example... --Dave 2 Quote Link to comment Share on other sites More sharing options...
Dave Stewart Posted February 14, 2019 Share Posted February 14, 2019 Here's a .hip with a sample setup, I'm sure there's a more efficient way to do this but it does work! I'd also recommend building your own meshing setup VDB from particles/particle fluid but since you can output VDB's from the PFS HDA this works too. --Dave DStewart_FLIP_Meshing_Blend2Fuilds_01.hiplc 5 Quote Link to comment Share on other sites More sharing options...
HM_2020 Posted February 14, 2019 Author Share Posted February 14, 2019 Awesome Dave cheers! Quote Link to comment Share on other sites More sharing options...
ahmedhindy Posted July 22, 2022 Share Posted July 22, 2022 On 2/14/2019 at 8:10 PM, Dave Stewart said: Here's a .hip with a sample setup, I'm sure there's a more efficient way to do this but it does work! I'd also recommend building your own meshing setup VDB from particles/particle fluid but since you can output VDB's from the PFS HDA this works too. --Dave DStewart_FLIP_Meshing_Blend2Fuilds_01.hiplc this is awesome, but how would you combine 2 beach tanks sims for example together, the mesh doesn't look right sadly Quote Link to comment Share on other sites More sharing options...
