How could I force point normals to facing to a correct direction?
Masoud
Hello;
Please take a look at image bellow (and attached hip file).
I would like to expand boundary of a flat geometry  (without adding any new points), so I tried to use Peak SOP. The problem is I can't align point normals to a right direction.
Normals.hip
Edited by Masoud
Here  is  how  I  have  handled  that  in  the  past.  Use  a  tube  or  ring  around  the  exterior  and  transfer  the  normals  from  the  outer  object  to  the  inner  one.
After  looking  at  the  image,  I  guess  that  is  not  right  either..?
ap_Normals.hiplc
Edited by Atom
ap_Normals.hiplc
Hi "Atom"; normals are not correct.
On 2/23/2019 at 5:09 PM, Atom said:
What  about  something  like  this?
Use  a  polyextrude  to  generate  vertex  normals,  then   use  a  wrangle  to  throw  away  the  newly  extruded  points?
ap_Normals.hiplc
I don't want to change geometry topology (I would like to keep point numbers intact).
This seemed like an interesting VEX challenge and I wanted to give it a go :)
Searched for a solution and found this https://stackoverflow.com/questions/14066933/direct-way-of-computing-clockwise-angle-between-2-vectors
Used that in a wrangle node to determine if a corner is convex or concave and added some other stuff and so far it seems to work.
For now, the solution works only for closed curves and treats them as 2D shapes on a XZ plane.
compute_normals.hiplc
Edited by berglte
  • Like 4
