How could I set a point's normal, to a direction between two half-edges?
Masoud
Hi;
Using a point wrangle, I retrieved angle between two half-edges of a point:
int SelectedPoint = 1;
int SelectedPointHedge = pointhedge(0,SelectedPoint);
int AngleSrcPtnum = hedge_srcpoint(0,(hedge_presrcpoint(0, SelectedPointHedge)));
int AngleDestPtnum = hedge_dstpoint(0, SelectedPointHedge);
vector SelectedPointPos = point(0, "P", SelectedPoint);
vector pApos = point(0, "P", AngleSrcPtnum);
vector pBpos = point(0, "P", AngleDestPtnum);
vector V1 = normalize(pApos - SelectedPointPos);
vector V2 = normalize(pBpos - SelectedPointPos);
f@angleRad = acos(dot(V1,V2));
How could I set(rotate) that point's normal, to a direction between two connected half-edges?
Thanks for helping.
Angles.hip
if you average the cross products of the vector of the edge directions of the corners: cross(normalize(pos1-pos2), {0,1,0}) and  cross(normalize(pos0-pos1), {0,1,0}), you should have your vector (or the anti vector not sure from the top of my head)
Edited by acey195
