How could I pin points on a vellum cloth, to an animated geometry ?
Masoud
Hi;
To pin some points on a vellum cloth, to an animated geometry, I tried these steps:
1) I add a “Vellum Attach to Geometry” SOP.
2) I grouped boundary points (“pin” group) on my cloth geometry.
3) In “Target Path” on “Vellum Attach to Geometry” SOP, I set path of my animated geometry.
but it doesn't work !
Thanks for helping.
Vellum_Pin to target.hip
I find another solution, so I add a "Pin to Target" vellum node, but it needs that all point numbers be matched point to point (All Pin point numbers to all Target point numbers)!
In my scene points on cloth starts from 0 to 49, and on animated geometry they are from 1 to 50 .
How could I match these point's numbers?
Edited by Masoud
you're overcomplicating things too much..
vu_Vellum_Pin to target.hiplc
If you look in Cloth, you'd see I defined 'Cloth' only for the patch. Technically you can leave it blank to define all as cloth (but later on you pin the 'drum' part of the geo), it will still work but..slooooooooow.
Hence to define only the patch part as cloth, then pin the rest of the drum as per user hand animation, much faster.
Edited by Noobini
Thank you "Noobini", very helpful.
