Understanding Solver SOP
Hi !
I'm pretty newb in Houdini and after a few months of training myself I'm trying now to create my own setup.
Here I want to move points from a grid randomly to x or y position. A random value is generated every seconds to change the direction and the axis of the next move of each point. I already understand it must be completed with a solver sop, but I can't understand why amplitude is multiplied when I move points into the solver. I need to scale down a lot the movement.
Anyone can tell me why ? Or just take a look to my project file here. Could be nice to have a little help to understand this issue.
Thanks
Dot_Grid.hiplc
Edited by Darkpulse
Hey! I'm not sure I understand the effect you would like to make but a solver completes all of your processes and then at the next frame, the input is where it left off from the previous frame and so on. This is probably why you feel like the amplitude is getting multiplied/doubled?
Cg wiki has some good examples of useful ways to use a solver: http://www.tokeru.com/cgwiki/index.php?title=The_solver_sop
Because you're adding to their position by the Current Time (which always increases 1,2,3,4,5,6), not a time step (which is small and constant 1/24).
So, change @Time to @TimeInc and you should get predicable results.
Thanks, that's logic now for me ! Works fine.
