Vellum Curtain Simulations constraint Issues + HIP File and Obj
ManteDec
Hi,
Iam trying to figure out how too simulate curtains with Vellum , i have and animated pin constraint network but it does not seem to affect my final result , did i forget to emplement something? Anyone can help me out?
Thanks in regards
curtain.hipncFetching info...
StartGeoV2.objFetching info...
Edited by ManteDec
  On 3/25/2019 at 8:30 PM, markingleukc said:
I believe you need to add animation to the curtain for the pinned points to connect to. Even if you add animation to the whole geo and plug it into the vellum solver, the solver only takes the first frame of the geo - unless the points are in a pin group.
curtain_fix.hipncFetching info...
Ok thank you so much I will look into your Hip File
Is there a way to keep my exisiting point for the contraint network instead of the animation of my copy so my curtain animation follow the curtain rings? now its a squash in the transform node
disabling it will give the following results
Edited by ManteDec
  On 3/26/2019 at 3:09 AM, Noobini said:
here's a basic setup/proof of concept...just keep it simple. Slowly add more things/collider in as you need them.
Don't have EVERYTHING in at once, you'll get bamboozled and can't debug things.
vu_vellumCurtain.hiplcFetching info...
thanks i will look into it
  • 1 year later...
I know it was a long time ago you posted this, but I wanted to thank you and let you know that it was very helpful.
