How do pyro collisions work?
evanrudefx
Hello,
Could anyone explain exactly how pyro collisions work? In some cases, it doesn't seem like collisions with the smoke solver are "real" when using moving colliders. It seems like 2 things happen when using an animated static object:
1. Takes the velocity from the collider and advects the smoke with it
2. Delete any density that goes inside collision object (can be disabled)
Look at my gif. If I disable velocity from the collision nothings happens. The density just gets deleted. In the example I turned off correct collisions for better visualization. If the collisions were "real", I would expect the density to move when the collider moves, then stop once the collider stops since no velocity from the collider is being applied.
Any ideas?
smoke_collision_test.hip
Edited by ejr32123
I guess I don't get what the problem is? You could add drag.
Your example shows the default, smoke existing in the vacuum of space. Why would you expect it to slow down in a frictionless environment?
There really isn't a "problem" it is more so trying to understand how collisions work. I am not trying to achieve a look or do some effect. I am just wondering how collisions work. Just trying to see if what I think is correct about collisions:
Edited by ejr32123
Hi Evan,
Here is what I think:
1. Afaik, you are right. Important field here is the collisionvel. In the second example, in SOPs, you set the collider's velocity to 0 ... so although in SOPs, the object is "moving", DOP sees its velocity as 0. So the "collisionvel" field is not affected by SOPs.
2. You are also right. If you keep the default "Correct collisions" on, then the "unaffected" density gets erased inside the collider.
I created this script "Find all parms referencing this parm" to dig deeper into DOPs. If you have any questions, I will gladly explain how to work with the tool. The blog post is rather minimal:
http://lex.ikoon.cz/find-all-parms-referencing-this-parm/
The script found the "collisionvel" here inside the Pyro Solver:
NODE: gasenforceboundary1   // PARM: Collsion Value   // RAW: collisionvel
NODE: buildcollisionmask   // PARM: Collision Velocity Field   // RAW: collisionvel
NODE: clean_collisionvel   // PARM: Dest Field   // RAW: collisionvel
NODE: clean_collisionvel   // PARM: Source Field   // RAW: collisionvel
The "Correct Collision" is referenced by these:
NODE: smokesolver_build2   // PARM: Correct Collisions   // RAW: ch("../correctcollision")
NODE: enable_correct_collisions   // PARM: Default Switch Value   // RAW: ch("../correctcollision")
NODE: clamp_inside   // PARM: Field   // RAW: `chs("../correctcollisionfields")`
NODE: color_correct_collisions   // PARM: Enable Solvers   // RAW: ch("../correctcollision")
And the "Velocity Scale" (collisionsource1) is referenced just by this node (Trail SOP)
NODE: compute_velocity   // PARM: Velocity Scale   // RAW: ch("../velscale")
  • Thanks 2
Btw you can also add Visualiser to the "collisionvel" field (it is not visualized by default)
- unlock the /obj/smoke_no_vel/dopnet1/pyro/smokeconfigureobject2
- find the "collision_velocity" node
- add a "Vector Field Visualization" node
Connect and set it, something like this:
  • Like 2
  • Thanks 2
Hth, few more notices:
- now I found this great answer:
   https://www.sidefx.com/forum/topic/55015/#post-246795
- collision field is just a scalar field
- btw have you seen this great explanation? At 29:00 Jeff talks about divergence https://vimeo.com/42988999
The "make_divergence_free" part of smoke solver is three steps
( 2.A or 2.B or 2.C, depends on the method you choose)
1. Gas Enforce Boundary
http://www.sidefx.com/docs/houdini/nodes/dop/gasenforceboundary.html
2.A  Gas Project Non Divergent
https://www.sidefx.com/docs/houdini/nodes/dop/gasprojectnondivergent.html
2.B or 2.C Gas Project Non Divergent Multigrid (or its OpenCL version enabled)
https://www.sidefx.com/docs/houdini/nodes/dop/gasprojectnondivergentmultigrid.html
3. Gas Feedback
http://www.sidefx.com/docs/houdini/nodes/dop/gasfeedback.html
Edited by ikoon
  • Like 3
So, one more notice about the creation of the collitionvel field:
Inside the Smoke Solver, there is the Gas Build Collision Mask node.
From the docs:
The Gas Build Collision Mask DOP builds a collision field that represents where affector objects overlap with the fluid field. It generates a signed distance field which is negative inside colliding objects and positive outside. It also generates a collision velocity field that stores the velocity of the affector object closest to each point.
http://www.sidefx.com/docs/houdini/nodes/dop/gasbuildcollisionmask.html
  • Like 2
