morn66 Posted April 16, 2019 Share Posted April 16, 2019 Hi everyone, I want to create 10 wooden plank with small variation. I used an offset noise inside a for-loop to generate different plank. The problem I have is that I want at the end of the loop to save the bgeo to disk but I dont know how to tell the for-loop to execute the save operation after each iteration. (because I can't connect the ROP geo to the output). Everything works if I go One by one and do a manual single pass. Thanks Quote Link to comment Share on other sites More sharing options...
avak Posted April 16, 2019 Share Posted April 16, 2019 What a intersting question I just got the same problem . Quote Link to comment Share on other sites More sharing options...
morn66 Posted April 16, 2019 Author Share Posted April 16, 2019 (edited) Finally I have found another solution that can achieve the same goal. Insted of creating the noise offset inside the loop, I use $FF to change the offset overtime. So I can set my Rop_Geo to render frame from 1 to 10. (dont need the loop anymore) Maybe it will work with what you want to achieve @avak. Edited April 16, 2019 by morn66 1 Quote Link to comment Share on other sites More sharing options...
Jesper Rahlff Posted April 16, 2019 Share Posted April 16, 2019 alternatively you could also just have put $FF into your foreach-end single pass condition and then your rop after the foreach. Write out 10 frames, get 10 variations. 2 Quote Link to comment Share on other sites More sharing options...
avak Posted April 27, 2019 Share Posted April 27, 2019 On 4/16/2019 at 5:37 PM, morn66 said: Finally I have found another solution that can achieve the same goal. Insted of creating the noise offset inside the loop, I use $FF to change the offset overtime. So I can set my Rop_Geo to render frame from 1 to 10. (dont need the loop anymore) Maybe it will work with what you want to achieve @avak. nice one, very clever Quote Link to comment Share on other sites More sharing options...
Butachan Posted April 27, 2019 Share Posted April 27, 2019 On 16/04/2019 at 4:43 PM, Jesper Rahlff said: alternatively you could also just have put $FF into your foreach-end single pass condition and then your rop after the foreach. Write out 10 frames, get 10 variations. Yep I would have recommended this as well as this way you may not even need to run a for loop. I did a similar setup to create a few instances to render later. Quote Link to comment Share on other sites More sharing options...
