Follyx Posted May 31, 2019 Share Posted May 31, 2019 is there a opinion to jump to an other node in a wranglesop? I.e.: in an if choice depending on the ouput (0/1)? if(i@test == 1) goto node..... Quote Link to comment Share on other sites More sharing options...
Atom Posted May 31, 2019 Share Posted May 31, 2019 (edited) You could use a switch for that. Take the result of, i@my_result from the wrangle and use it to control the switch index. Then the wrangle will determine which set of nodes end up feeding the final display flag node. Edited May 31, 2019 by Atom Quote Link to comment Share on other sites More sharing options...
Follyx Posted May 31, 2019 Author Share Posted May 31, 2019 Thank you. I forgot that... more elegant would be a wrangler.... any idea? Quote Link to comment Share on other sites More sharing options...
CinnamonMetal Posted May 31, 2019 Share Posted May 31, 2019 (edited) @Follyx as @Atom mentioned an expression in the switch sop; as for a wrangler,you could use Opinput_x in a condition. Edited May 31, 2019 by CinnamonMetal Quote Link to comment Share on other sites More sharing options...
