davidyannick Posted June 5, 2019 Share Posted June 5, 2019 I'm trying to save my group preset as permanent default on Houdini 17.5 on windows 10 and each time even if I strat Houdini as admin I have this message "Couln't save preset ... check file permission ? Any idea ? Thanks Quote Link to comment Share on other sites More sharing options...
eikonoklastes Posted June 19, 2019 Share Posted June 19, 2019 I've been having the same issue. Still haven't found a solution. Have you had any luck? Quote Link to comment Share on other sites More sharing options...
davidyannick Posted June 19, 2019 Author Share Posted June 19, 2019 12 minutes ago, eikonoklastes said: I've been having the same issue. Still haven't found a solution. Have you had any luck? The problem was in houdini.env, try to modify it above all HOUDINI_PATH Quote Link to comment Share on other sites More sharing options...
eikonoklastes Posted June 19, 2019 Share Posted June 19, 2019 Thanks for pointing me in the right direction. The issue arises after installing the Game Development Toolset. The old path was HOUDINI_PATH = $HOUDINI_PATH;$APPDATA\SideFX\GameDevToolset\17.5\1.163;& I modified it to be: HOUDINI_PATH = $APPDATA\SideFX\GameDevToolset\17.5\1.173;$HOUDINI_PATH; Everything works as expected now. 1 Quote Link to comment Share on other sites More sharing options...
gui Posted July 22, 2019 Share Posted July 22, 2019 On 19/06/2019 at 6:31 AM, eikonoklastes said: Thanks for pointing me in the right direction. The issue arises after installing the Game Development Toolset. The old path was HOUDINI_PATH = $HOUDINI_PATH;$APPDATA\SideFX\GameDevToolset\17.5\1.163;& I modified it to be: HOUDINI_PATH = $APPDATA\SideFX\GameDevToolset\17.5\1.173;$HOUDINI_PATH; Everything works as expected now. Aren´t you setting up the default search folders with "&"? If I don´t append the "&" at the end, I can´t get houdini to work, but otherwise I can´t save the presets... 2 Quote Link to comment Share on other sites More sharing options...
gui Posted July 22, 2019 Share Posted July 22, 2019 (edited) I figured it out. Just adding a space before the "&" did the trick. Edited July 22, 2019 by gui Quote Link to comment Share on other sites More sharing options...
burakumincgi Posted August 14, 2019 Share Posted August 14, 2019 none of the above is working for me, can get Houdini to save as permanent default, I need that to save a license in a tool Quote Link to comment Share on other sites More sharing options...
burakumincgi Posted August 14, 2019 Share Posted August 14, 2019 found a solution, instead of pressing "Save as Permanent Default" just click on "save Preset" and then "Save as Permanent Default". no need to edit the env file Quote Link to comment Share on other sites More sharing options...
gui Posted August 15, 2019 Share Posted August 15, 2019 yeah, but that shouldn´t be a problem. For other reasons, I changed the way I edit the HOUDINI_PATH env variable: I left the houdini.env as defaults, but used the new approach, with "packages". It´s cleaner and didn´t generate any permissions errors. Quote Link to comment Share on other sites More sharing options...
bobc4d Posted November 18, 2019 Share Posted November 18, 2019 I was getting this error too. there was no path in "save preset to", once I did that it worked like a charm. Quote Link to comment Share on other sites More sharing options...
gui Posted November 18, 2019 Share Posted November 18, 2019 13 hours ago, bobc4d said: I was getting this error too. there was no path in "save preset to", once I did that it worked like a charm. Look for "packages" in the help. It´s cleaner and will solve this bug. 1 Quote Link to comment Share on other sites More sharing options...
bobc4d Posted November 19, 2019 Share Posted November 19, 2019 Thank you gui, much appreciated Quote Link to comment Share on other sites More sharing options...
foam Posted August 7, 2020 Share Posted August 7, 2020 Thanks guys! Had this issue forever and was driving me nuts. This really helped! Quote Link to comment Share on other sites More sharing options...
eikonoklastes Posted August 8, 2020 Share Posted August 8, 2020 On 8/7/2020 at 4:28 AM, foam said: Thanks guys! Had this issue forever and was driving me nuts. This really helped! This was a bug that was fixed ages ago. You shouldn't be having this issue on any recent version of Houdini. Quote Link to comment Share on other sites More sharing options...
foam Posted August 15, 2020 Share Posted August 15, 2020 On 8/7/2020 at 9:39 PM, eikonoklastes said: This was a bug that was fixed ages ago. You shouldn't be having this issue on any recent version of Houdini. It may have piggybacked with me copying over preference files into newer versions of Houdini Quote Link to comment Share on other sites More sharing options...
