UV map saturn rings in Mantra
Hi houdinist !
I am trying to apply saturn ring texture in mantra but I failed to reproduce the texture mapping in attachement (done in blender),
someone could help ? I tried to rotate UV by an angle of 90° over each face, but I don't know how to achieve this
hip file in attachment with saturn ring texture
thanks
Alex
ring.hipnc
You can turn a wide grid into a ring using sine and cosine on the bounding box of the grid. That way you can also create UVs on the fly.
float radius_inner = chf('inner_radius');
float radius_outer = chf('outer_radius');
vector bbox = relbbox(0, v@P);
vector bbpi = fit01(bbox, -M_PI, M_PI);
vector uv = set(bbox.z, bbox.x, 0.0);
v@uv = uv;
vector pos = set( cos(bbpi.x), 0.0, sin(bbpi.x) );
pos *= fit01(bbox.z, radius_outer, radius_inner);
v@P = pos;
saturn_rings.hipnc
